跳转到主内容
Contour 于2012年所生产的防水运动相机。
Why will my camera not mount properly?
The camera will not slide into a sticky mount and/or screw in to the tripod screw in.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
If your camera will not mount properly, it could be because the slots on the side of the mounting piece are stripped, not allowing you to slide in mounting pieces, or the tripod screw-in is stripped. In this case, the easiest solution to either or both of these problems is to replace the mounting piece completely. To do this, follow the mounting piece replacement guide on iFixit located at Contour Roam2 Mounting Piece Replacement.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Matthew Kofsky 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 246
