跳转到主内容
20", 23", 和 30" LCD 显示器 发售于2004 于 2010年停产。
How many CCFL tubes in 30" display
Wondering if somebody can tell me how many CCFL's there are in the Cinema 30 inch display.
Also, if you've have taken one apart, how long are the CCFL's and what diameter?
I'm trying to find some replacements.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
4条评论
Hi,
Did you ever find a solution? Could you share if so?
I have two that I would like to fix.
Thanks
完成的
Hi,
many thanks for asking. well it was a other problem. the CCFL's are not damaged. the line driver are defective.
完成的
oh, thank you for letting me know...it seems you had luck in fixing it, I hope I will be able to do the same.
完成的
I have two 30" displays and they are both showing dimming and yellowing with age but are otherwise perfect. Would replacing the CCFL's help? Does anyone know where I should look to find out?
完成的
添加一条评论
2个答案
已选择的解决方案
Here's one of the last sources I know of for CCFL's: LCD Parts.Net.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
I think there are totally 16 CCFLs distributed horizontally & evenly at the back of the LCD. I don't know exactly how long they are, but they are at least as long as the width of the screen, so the illumination could be even.
I've been wondering why there is so little information about the aluminum displays (A1081, A1082, A1083). I'm pretty sure there are still many being used, and some may need attendance. Maybe ifixit.com could show some instructions on this.
这个答案有帮助吗?
得分 5
添加一条评论
添加你的答案
Mark Ellis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 4,138
