跳转到主内容
Repair guides and support for wired or wireless devices that provide internet connectivity.
Why isn't my Belkin Range Extender working?
after long time having issue with connectivity and speed issue i git a new belkin range extender and now it is not working . its just 1 month old help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
not working my belkin range ,what should i do?
完成的
添加一条评论
3个答案
已选择的解决方案
range extender is a plug-and-play device after setup. First connect your computer with range extender with a cable then open the default gateway IP in your browser and now put your router name and password and you will get Belkin range extender extended network as you want for more contact belkin . i hope that works for you thanks
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
i think this Can Be a Easy Fix Cause last Night i had the same issue with my belkin extender . Just Reset Your Belkin Range Extender And Setup it Again Like Its a New Device. Since its a Plug and Play Device it Will Work . Follow This Link Belkin.range
See if this Helps You Solve the Issue
这个答案有帮助吗?
得分 4
添加一条评论
from my understanding this issue could be fixed if One can Do Proper Troubleshooting. Here is How One should fix Belkin range extender-
  1. First Restart the Belkin range extender & check whether your router has an active connection from ISP.
  2. Carefully Reset Belkin range extender using the Reset Key At the back Or if you could log into Belkin extender console
  3. after the Reset Just Follow the standard Guidelines to Setup Belkin range extender as Given Instruction
also i think with increasing Demand for Mesh Routers will Outrun the Traditional Router & extenders in next 5-10 Years.
Happy Ifixing
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
keven 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 48
总计 29,888
