跳转到主内容
A corded phone with companion cordless phone developed by Uniden.
8 个问题 查看全部
There is noise/static on the line
When I go to call someone i keep hearing static on the line.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
For troubleshooting, Uniden D1688 Troubleshooting.
完成的
添加一条评论
2个答案
已选择的解决方案
Check for interference from appliances (microwave ovens, TV's etc.). or wireless devices (baby monitors, WiFi equipment, etc.). Move the handset or base away from the interference source.
If you use a telecoil hearing aid, turn on T-coil mode in the Handset Setup menu. T-coil mode shortens talk time, so keep your battery fully charged.
Check Troubleshooting page Uniden D1688 Troubleshooting Repair
这个答案有帮助吗?
得分 1
1条评论:
Randall the troubleshooting guide is just a placeholder (has nothing).
完成的
添加一条评论
最有帮助的答案
If all of your handsets have static then its likely your phone line has a problem.
You should call your phone service provider to check the lighting arrestors and your phone lines grounding. Often the arrestors wear-out and your grounding rod and/or power line ground connection is not good. In some cases the grounding is though your waterline (copper line). Corrosion can effect the effectiveness of the ground.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Zachary 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 6
总计 2,648
