跳转到主内容
加入维修社区 - 创建账户
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
Home Button ribbon cable
Hi. My home button has not been working properly (as in it only works sometimes but not all the time). I oppened up the ipad because i needed to replace the screen anyway and foung the home buttons ribbon cable is slightly torn. Is there a guide for previous apple device that could be applied to replacing the cable?
Thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi Nick
try this iPad Air Wi-Fi Case Button/Cable Replacement
http://makemoneyrw.com/WIN-AppleiPadAir
这个答案有帮助吗?
得分 2
2条评论:
Thanks this really helped
完成的
The information about getting the home ribbon cable apart at the home button is not there. Needs more information between step 43 and 44.
完成的
添加一条评论
此回答最初是针对另一个问题
The button is separate from the cable, on the back of the digitiser you'll see the home button bracket just use a metal spudger to break the clue holding the bracket to the digitiser, the button will now be left, your replacement cable will likely come with the bracket attached so just connect to the logic board and glue the bracket to the digitiser positioning it correctly over the home button.
这个答案有帮助吗?
得分 0
3条评论:
The cable I received has no bracket with it.
完成的
you can remove the cable from the bracket by picking it off, its only glued on.
完成的
There is a bracket between where the old home button ribbon cable and home button switch. I would have to try to send pix of what I refer.
完成的
添加一条评论
添加你的答案
Nick071 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 188
