跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
Removing Home ribbon cable
When I took the iPad Air apart to change the battery the home ribbon cable tore in two. I ordered a new cable now how do I get the old one off at the home button?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I looked at the ribbon cable guide. There is nothing said about how to remove the ribbon cable from the home button should be mentioned around steps 43 and 44 of the guide
完成的
添加一条评论
2个答案
最有帮助的答案
Hi Nick
try this iPad Air Wi-Fi Case Button/Cable Replacement
http://makemoneyrw.com/WIN-AppleiPadAir
这个答案有帮助吗?
得分 2
2条评论:
Thanks this really helped
完成的
The information about getting the home ribbon cable apart at the home button is not there. Needs more information between step 43 and 44.
完成的
添加一条评论
The button is separate from the cable, on the back of the digitiser you'll see the home button bracket just use a metal spudger to break the clue holding the bracket to the digitiser, the button will now be left, your replacement cable will likely come with the bracket attached so just connect to the logic board and glue the bracket to the digitiser positioning it correctly over the home button.
这个答案有帮助吗?
得分 0
3条评论:
The cable I received has no bracket with it.
完成的
you can remove the cable from the bracket by picking it off, its only glued on.
完成的
There is a bracket between where the old home button ribbon cable and home button switch. I would have to try to send pix of what I refer.
完成的
添加一条评论
添加你的答案
macmike 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 365
