跳转到主内容
一个广泛的电子产品维修指南,从家和汽车音响到计算器。
26452 个问题 查看全部
Does the iCracked Ultrasonic Cleaner work?
I'm looking to purchase an ultrasonic cleaner to recover water damaged iPhones. I've seen them in the $150-$400 range. But I came across one on iCracked.com for only $45. I was wondering if anyone has had any experience with this ultrasonic machine or if anyone has an opinion on it. Yes, I understand the whole you get what you pay for, but I cracked is a pretty reputable products. Any feed back would be appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Do not use alcohol it is FLAMABLE. Ultrasonic cleaning and heat will produce alcohol vapors that can flash. Use Branson EC diluted and rise with 90%+ (non rubbing) alcohol. Dry boards in small oven at 200F for an hour or so.
Use sweeping ultrasonic cleaner to minimize chances of ultrasonic damage. Remember you get what you pay for in equipment. Used quality is better than new junk.
这个答案有帮助吗?
得分 1
4条评论:
Don't put the boards in the oven, that's a really stupid idea.
完成的
@gigabit87898 that is actually common practice after ultrasonic cleaning. Watch that language on here....
完成的
Wouldn't that just create cold solder joints?
完成的
definitely not at 200F check for the melting point of solder etc. on here Hair dryer for logic board reflow?
完成的
添加一条评论
最有帮助的答案
I used to buy ultrasonic cleaners for our company. Does it come with built-in heating? That type are particularly good, over those that don't have it. The key thing to look for when buying an ultrasonic cleaner is not just brand or build quality or materials. You also need to check if the product is supported with spare parts availability - especially the sensors as they are near-impossible to get hold of at anything like a reasonable price. Now, the single most important thing to look for in an ultrasonic cleaner, is quite surprisingly, its size compared to the parts you are putting in there. You need to match the cavity size to the parts size EXACTLY. If you think bigger is better, you'd be wrong! The effectiveness decreases considerably to almost nothing when you have tiny objects inside a large cleaner. Most buyers do not take this into consideration & blame the product or the cleaning solution, etc.
这个答案有帮助吗?
得分 2
添加一条评论
Yes, and it can be very effective, but I would recommend using their product with an alcohol solution to help clean debris from the PCB.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Britt Bay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 373
