跳转到主内容
型号 A1213或A1218,闪存容量:8、16及32GB
216 个问题 查看全部
not turning on!
I need some help with my 1st gen 16 GB iPod touch! Last night, I synced my ipod with my itunes (transferring files-a few photos, videos, etc), and it was taking awhile. It was kinda late, so I went to bed and let it finish overnight. Then when I woke up the next morning to check on it, my iPod wouldn't turn on when I pressed the home button. I tried charging it on my home charger, and it's not even responding to that! I had this Touch for 2 years now, and this is the first time this happened. It might be the battery, but I need to be certain. Can anyone help? Please and thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Just to check, what happens when you reconnect to iTunes? Does it do anything at all?
Check out the troubleshooting guide for further steps.
I hope this helps!
这个答案有帮助吗?
得分 0
1条评论:
acctully that did help! and that my battery was really dead! XD! thx
完成的
添加一条评论
have you checked the battery voltage? it should be above 3.7v some times you have to recharge it using a 12v or 9v DC adapter to bring it back to life, do this only for about 20-30 seconds the battery should hold charge above 3.7. be sure to do this when battery is NOT attached to the mainboard. if the battery holds its voltage and the ipod is still not turning on, and pc does not show a thing when you plug it in, double check your assembly, lcd, battery welding, front pannel.
这个答案有帮助吗?
得分 0
添加一条评论
How do i check if my iPod touch battery is dead if it dosn't turn on?
Just making sure so i don't buy another battery for nothing.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Thomas 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 7
总计 5,932
