should I change my 5400rpm hd to the new SSDs?
MacBookpro 13" unibody 09
I interested with new SSDs technology, so should i change my spin hd to new SSDs?
You would probably be happier replacing the optical drive with an SSD. That way you can get away with a smaller SSD and have the old drive or a new 500 GB hard drive for storage.
Here are three SSD drives:
http://www.ifixit.com/Mac-Parts/MacBook-...
Here's the enclosure:
[关联产品丢失或禁用: IF107-078-1]
Here's how to install it:
[关联产品丢失或禁用: IF107-071-1]
As little as I use a optical drive, an external USB/Firewire dual layer LaCie LightScribe drive works great for me.
http://www.lacie.com/products/product.ht...
or you can put the existing optical drive in an external enclosure like this one:
这个答案有帮助吗?
I read an review on using SSD drives as a primary laptop hard drive and it indicated there were more beach ball events and they lasted a fair amount of time. Please look at the video on the Seagate site below to see a rating of the types of drives.
这个答案有帮助吗?
+ agreed, I just had major problems with a SSD as primary drive in a 2010 Unibody
I'm in the process of doing that myself. I just bought a 240GB Mercury Extreme Pro SSD new, off of eBay, for $400. Same as the one here:
http://eshop.macsales.com/shop/internal_...
I'm going to try to do a complete backup of my current hard drive onto the new drive via SuperDuper, and then make the swap and hope it starts up with everything in place. We'll see.
这个答案有帮助吗?
I just put a 120Gb SandForce based drive in the MBP. WOW! What a difference.
I've got the iMac for any serious work, and actually do need every hour of battery i can get, so 120Gb ended up being enough space and a 2nd HDD/SSD would just kill the battery faster.
这个答案有帮助吗?
I use a LOT of my archived video & Pictures, and before I even learned about a SSD, I purchased a TB drive for my 17" MBP unibody. Now being that I really don't need the OD (I have an external Lightscribe as well, as the author), what size SSD should/could I place in my OD spot? AND--do I run the OS from the SSD, and then just place any media, onto the TB drive?
Now, with that question asked, where do my documents, desktop email etc. go onto? Furthermore, when I do a back up of my Time Machine, what drive does it back up. Sorry for sounding like a tool, but this is honestly the first time, that I am hearing of the SSD drives. The storage capacity just sounds so small,,,so I guess you can say that I just don't "get it".
I just want to know what is the smallest SSD drive that I can get away with to replace the OD, and use the internal TB for any storage needs.
Thanks!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 7,649
