跳转到主内容
加入维修社区 - 创建账户
发布于2013年11月22日的微软第三代Xbox游戏主机。
programming new optical drive for replacement
hi im just wondering if you have to program THE NEW optical drive IN XBOX ONE LIKE THE OLD 360S
THE TUTORIAL SHOWS THAT WE JUST SWAP THEM OUT BUT WILL GAMES WORK ON THE NEW DRIVE ?? i read that the drives are motherboard locked so how does this tutorial work ?? I also read that you have to swap out the board on the original drive to the new one in order for it to work but the tutorial does no such thing can someone shed some light on this thanks !!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
My Xbox one S has no optical drive at all.. How do I install a new one if I don't have a daughter board??
完成的
@rottenova Simple, it's just not possible.
完成的
添加一条评论
2个答案
已选择的解决方案
You have to swap the daughterboard from the origianal optical drive that came with the console from the factory with the daugtherboard with the new drive you are going to install. Each optical drive daughterboard is married to the motherboard so it must stay with that motherboard even if the drive is swapped out.
You will need to desolder the wires for the motor and solder them back on the replacement board.
这个答案有帮助吗?
得分 5
4条评论:
I’ve done that, but my drive still won’t read games or DVDS what do I do in this case?
完成的
@Nate Khan Replace the laser
完成的
Is there anyway to know what daughterboard is attached to what motherboard? I have a bunch of systems that have been mixed up due to a big move. I can't find this answer anywhere. Specifically the Xbox One S.
完成的
Same here^^^ is there away to swap out the motherboard chip that links the disc drive to one from another Xbox
完成的
添加一条评论
I replaced my Disk drive on my original xbox one Halo version. With a Disk drive Order from Amazon. Unsoldered and re soldered daughter board to new Disk drive. It will take the disk in try to read it then I get a black-and-white Square message DVD Blu-Ray disk or game does not recognized please insert and DVD blu Ray disk or game. How do I get my xbox to start to read disks again
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sahilvinay 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 27
过去 30 天: 101
总计 10,687
