跳转到主内容
加入维修社区 - 创建账户
第六代 iPod classic 。机型型号 A1238,80/120/160 GB 机械硬盘,黑色或银色金属前面板。
just don't start up when connected
while loading music from itunes to the iPod, the iPod locked up, shut down and the apple icon screen started to go on and off while making a clicking sound and thats all it does now when plugged into the base or computer until the battery runs down, then it goes off. when plugged back in and the battery gets a little charge, it starts all over again.
anyone have any ideas ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Can't connect to itunes. also tried pushing and holding menue and start buttons and same thing.
完成的
添加一条评论
1个答案
最有帮助的答案
Symptoms
You may need to restore or update your iPod, iPod mini, or iPod nano by placing it in Disk Mode if only an Apple logo appears when you turn it on.
iPod
Resolution
If this happens, the iPod software may have been damaged. Put iPod into Disk Mode, then restore or update iPod's software.
Put iPod into Disk Mode.
iPod should appear in the iTunes Source pane and on the desktop or in a Finder window, or in the My Computer window.
If a message appears that says the volume could not be mounted and asks if you want to initialize the disk, choose to initialize iPod's disk. Use Mac OS Extended format (HFS Plus) if you have a Mac, or FAT32 if you have a Windows PC.
Warning: This process cannot be undone. All of your songs, videos, and other files will be deleted. Always make a backup of your important data.
Follow the steps to update or restore iPod. If you manually put iPod into Disk Mode it may need to be reset before you can use it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
jim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 563
