跳转到主内容
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
screen not responding after replacement with low memory - HELP!
I replaced digitizer and LCD assembly on a Galaxy S4. It seemed to work fine initially, but client brought it back saying it stopped responding. The areas where the LCD shows does not respond (even though when I just turned it on it started responding for about a minute then completely stopped), but the touch buttons on either side of the home button respond. I going to try to reopen the phone and unplug/replug the digitizer from the logic board to see if that helps but I have a couple of concerns. I noticed that the phone says that memory is low and that some system features may not work as well as another notice stating that storage space is low as well. Could low memory and/or low storage space cause the digitizer to stop responding to touch?
Anyone ever seen this happen before? Any ideas on how to resolve this, other than the obvious "get another new screen"? Thanks in advance for any advice given.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Hey there, PCHookups.
Both of those problems could be caused by something not being properly attached if the digitizer cable and the connector for some of the memory weren't properly seated so I recommend opening it back up and double checking all the screws and cable connections.
Best of luck and let us know if that helps!
Spencer JR
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
PCHookups 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 145
