跳转到主内容
加入维修社区 - 创建账户
一款由 Dell 于 2013 年生产的便携式一体式触摸屏台式机。型号 W01A 可在设备右侧的支撑脚上找到。
Why won't my computer charge?
I am having trouble charging my computer. Every time I plug it in to the charger, it does not help. I have tried multiple outlets and it still does not work. Could this be the charger or is it something more complicated?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
It could possibly be the charger. Check to see if your charger wire has any cuts or distortions on it. If this is the case, the charger wire might be frayed and you will need to get a new one. Also, check to see if your charging port is working as well too. It might be blocked by a speck of dirt that won't allow the grooves of the charger to fit into the computer.
If none of these are the problem, your battery is probably not functioning properly. In this case, you will need to replace the battery. Here is a link to a battery replacement guide.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nick Werner 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 3,155
