跳转到主内容
The HTC Desire 510 Android smartphone was announced August 2014.
46 个问题 查看全部
Replacement of glass and/or touchscreen digitizer
I have torn this Desire 510 down and can not figure how to remove glass. No screws, no snaps nothing gives. Any help would be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 11
2条评论
Where can I buy the screen for this phone
完成的
You can go to eBay .then go to flashtechllc they will sell/send u a new digitizer n tools to do the dismantle/reassembly
完成的
添加一条评论
12个答案
最有帮助的答案
i fix these phones all the time and that is not correct about the screen. The HTC desire 510 has a small amount of adhesive tape not glue on the out er edge of the glass that holds it to the plastic bezel. The "best" way to deal with this is to us a thin pry tool or razor blade(be careful with them) and a heat gun or blow dryer. heat the screen around the edges of the phone and use your tool to get between the glass and the plastic. the heat will cause the adhesive to loosen up and then you can pry it up. I normally pry it up just enough to slide a playing card between the glass and the the plasstic and then slide the playing card down to undo the rest of the screen. Also you need to undo the logic board from the phone and pry the screen up form the top of the phone. the flex ribbon for the glass wraps under the lcd and the lcd has adhesive under it holding the lcd to the phone. so you have to heat the back of the phone with the battery and logic board out to get the lcd out and properly put a new glass in.hmmm... sounds a bit complicated so i might make a guide to show you.
这个答案有帮助吗?
得分 2
1条评论:
What is the tiny piece of metal mesh off to the side of the ribbons connection? And do I need to replace it?
完成的
添加一条评论
I hate to be that guy, but the Glass is glued directly to the screen. You are better off replacing the screen and glass at the same time. It is possible to heat the glue and remove the glass from the screen, but the odds of breaking the display are really high.
这个答案有帮助吗?
得分 1
添加一条评论
mbrady, that is not correct. The glass is actually not entirely glued to the screen. it is simply glued along the perimeter only. The glass digitizer has a layer of clear plastic sheet in its outermost layer that is directly above the LCD screen. The trick is to gently poke the glass digitzer at the edges. As you do so, you will notice the glass digitizer creating an air space between it and the screen. If you are able to carefully tear in only one section, preferably the corner of the clear plastic sheet, then you can create a handle, which you can pinch-hold to peel off the glass digitizer. Incidentally, if your glass digitizer is cracked in to umpteen glued fragmented, it actually makes it easy to peel off the rest of the glass digitizer cleanly.
This is an instruction prepped from experience, I did it exactly that way. Now if only HTC would have a clear opening for the glass digitizer interface cable so that i can insert it through to connect it to the logicboard. The reset is cakewalk.
Good luck.
这个答案有帮助吗?
得分 1
添加一条评论
HTC Desire 510 Touch screen Glass and/or LCD Display
这个答案有帮助吗?
得分 1
添加一条评论
Easy fix. Buy a heat gun electricians use (Milwaukee) makes a good one. Buy at any electric supply or possibly home depot. Takes 4-5 seconds along outer edge of glass and it comes off easy. Hard part is putting digitizer cable back thru slot without damage.
这个答案有帮助吗?
得分 0
添加一条评论
http://youtu.be/a5PEC-S72b8
这个答案有帮助吗?
得分 0
添加一条评论
Screen is cracked badly
这个答案有帮助吗?
得分 0
1条评论:
Wat is the cozt to get the phone fixed
完成的
添加一条评论
I just recently torn down my HTC Desire for a cracked screen.
If you like here is a link on a full tear down and put together...
https://youtu.be/a5PEC-S72b8
这个答案有帮助吗?
得分 0
添加一条评论
step by Replacement is on you tube
这个答案有帮助吗?
得分 0
添加一条评论
You have to use a razor blade place it in between the screen and the phone and it should lift out it's going to take a little bit of force but will pop out..
这个答案有帮助吗?
得分 0
添加一条评论
Try using a heat gun or iopener to soften the adhesive that holds the glass down.
这个答案有帮助吗?
得分 0
添加一条评论
heat the edges with a hair dryer to loosen the tape then carefully pry th glass away with a razor knife
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Roy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 22,074
