跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 个问题 查看全部
Broken iSight Camera Bracket
I recently changed the Macbook Unibody glass screen, However, I don't have the iSight camera bracket (as seen in step 23 of MacBook Unibody Model A1278 LCD Panel Replacement). Will my camera still work? Does does the camera bracket do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Well... Yes it will work.
But, it may not line up correctly within the window in the black mask of the cover glass so the image might be cut off.
The bracket catches the iSight camera (which is loose) so it is correctly aligned to the hole in the back mask.
I would recommend to try to find your old cover glass to retrieve it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sarah 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 77
