跳转到主内容
The HP 7 1800 is a 7" Tablet made in 2013 by HP. It is a WiFi and Bluetooth enabled device with a 0.3MP front facing camera.
Why is my device not turning on?
When I press and hold the power button, my device will not turn on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
Hello Todd,
The possible hardware causes are :
-Bad power on/off button
-Bad motherboard (some blown or non working component or part)
-Bad psu or battery (probably not if you tried powering on with and without AC adaptor)
-Bad battery (there are devices that canot work without battery, even if they are connected to AC)
Hope this can help a bit!
这个答案有帮助吗?
得分 1
添加一条评论
First, make sure your tablet is charged. If the device does not charge, try another charger. If this fails, the issue may be with the battery or the logic board. Try replacing the battery. If that does not work, you will have to replace the logic board. See HP 7 1800 troubleshooting for more information.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
TMD 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 1,022
