跳转到主内容
加入维修社区 - 创建账户
Model M8413 or A1007 / 600, 700, 800, or 900 MHz G3 processor
iBook G3 won't boot, can't install a system
Hello,
I got an old iBook G3 model A1007 900 MHz recently, but I never managed to make it works. I tried to instal an OS on it but it won't let me do it.. When I turn it on, plugged or not, the iBook make the noise of the start then a black screen appears and shows me a little icon with a "?" in the middle of the screen.
I have no idea how to reinstall something on it as nothing is working.
I can send you screenshot if needed.
Thanks alot
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
The question mark means that it can't find a valid operating system. First do you know if it has a hard drive? Are you trying to install from the original system installation disk or something else (please tell us what you are trying to use.
这个答案有帮助吗?
得分 3
3条评论:
Hi,
Yes it does has an hard drive as when I received it from my friend it was with an old OS all in chinese, but I haven't got an orignial system installation disk with it. I haven't try to use anything on it, I just wanted to use it :(.
完成的
Pre-Installed MacOS: 9.2.2 & X 10.2.4 Maximum MacOS: X 10.4.11
Here's the info on your machine: http://www.everymac.com/systems/apple/ib...
完成的
Where can I find the iso to burn it on a disk ? And how to make the iBook boot from this disk after ?
完成的
添加一条评论
添加你的答案
Fanny 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 265
