跳转到主内容
无线连接并控制您的苹果电脑。
89 个问题 查看全部
heat gun Alternative for the glue
Hey guy's why didn't you use a flat iron like for ironing clothes to remove the back of the BT keyboard?
The first time i used it was for my Palm III once to replace the battery pack. I can imagine that this will work with this keyboard too.
Mine left bottom corner was disabled by a small dog that put his feet on it to look out of the window and i need to remove the back too. the whole corner from the caps lock to the cmd key doesn't work anymore. so i think a flat iron will work better with a paper in between if needed to solve the the glue issue.
Most heat guns are at least 150 or 300 degrees Celcius wich is way to hot for that stuff.
Grts
Z
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Here's the teardown I did on this keyboard. Even using a glue solvent, I don't know how you repair it:
Apple Wireless Keyboard (A1255) Teardown
这个答案有帮助吗?
得分 1
添加一条评论
I'm guessing because the heat form a heat gun can be controlled easier since the heating element isn't in direct contact with the plastic. Using a flat iron on plastic and electronics sounds like an inherently bad idea to me, not only because if what i wrote above but also since it emits steam, not exactly what you want in your electronics.
这个答案有帮助吗?
得分 0
1条评论:
Not all Iron soles emits steam, on the lowest setting it doesn't you can always replace the paper with á towel.
完成的
添加一条评论
添加你的答案
Zathros 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 1,811
