跳转到主内容
第一代苹果iPad 配备有WiFi 提供16.32或64GB 型号为A1219 维修是直接的不需要任何加热。
130 个问题 查看全部
Is it possible to build an Ipad out of parts from online?
Hey Guys,
I was wondering if it's possible to build an ipad out of parts ordered from online?
LIke i found a few sites where you can get the LCD and the case, but i'm wondering if it's possible to order other parts like the logic board and the speakers. etc.
Would it be possible?
- Ez
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
6个答案
已选择的解决方案
Parted out an iPad will probably cost double what a brand new one does.
这个答案有帮助吗?
得分 4
3条评论:
That is unless you buy used parts. Also you'll have to pay shipping on every single part, not just one unit.
完成的
Buy one with a broken screen, then buy one with water damage.... Profit?
完成的
mayer is right!
The PCBs and the chips are expensive in small volume!
完成的
添加一条评论
it is possible but it cost a lot that it might not worth it.
这个答案有帮助吗?
得分 1
添加一条评论
and the best bit is, apple would not repair it, if something goes wrong...
i was going to buy one with cracked screen. i first was told by apple care "just bring it in, and we will fix it for you". then i have dug a bit deeper and have asked another apple care professional, if it really is replaceable in apple stores, he said to me, i would be turned away... i am not going to do anymore business with apple anymore. this iPhone is also the last one...
the way they make things is simply not good enough for me. if glass can be shattered so easily, why the $&@$ no one makes it out of plastic? i know, i am barking at the wrong tree...
这个答案有帮助吗?
得分 0
3条评论:
If you don't like Apple engineering just wait till you open an Acer ;-)
完成的
Open an ipad it not built all that good just like all other stuff coming from asia
完成的
Open an acer???, open an HP!!!!! The HP had like 3 tons of duct tape in it.
Apple engineering is actually pretty elegant compared to most other stuff out there.
完成的
添加一条评论
I bought %70 of the parts needed to build one myself. But the eprom chips have the preloaded software from Apple. And not to mention the flash hard drive. What I did do was order from A web site called Dealextream about %50 of the unit. We in Toronto Ontario Canada have a mall called Pacific mall. In it has about 200 small china like stores with the rest of the imports for the Ipad. You are almost assured that most stores only carry Ipad 1 parts in stock. Cost to date is about $300
Good luck
这个答案有帮助吗?
得分 0
添加一条评论
There are many iPads available on eBay that are bricked by what is called an "iCloud" lock and others which are cheap because they have shattered glass, etc. So Apple is checking serial numbers before it lets your machine work, or download apps, making building from scratch a non-starter. But swapping id from a physically broken machine into a locked chassis might be a doable project to get a cheap iPad.
这个答案有帮助吗?
得分 0
添加一条评论
How about taking the parts of a broken iPad screen with screen and attaching it to a larger touch screen for something like a diy touch table.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Esmond Ruslim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 27
总计 22,704
