跳转到主内容
The Skullcandy Air Raid is a wireless portable Bluetooth speaker released November 15th, 2013 which streams music from any Bluetooth-enabled device.
16 个问题 查看全部
Why won't my device connect to the Bluetooth?
My Bluetooth device will not connect to my Air Raid. How do I connect?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
2条评论
Trying to pair my Soundmine to my Samsung phone but get an "incorrect passcode" message. HELP!
完成的
How I connect my skullcandy in my MI note 3 ? It's some issues while I am using . Sounds has automatically up and down ? What I should do for it ????
完成的
添加一条评论
5个答案
最有帮助的答案
the sound mind i turn it on and connect to it. phone showes up increrect pin or passward how do i fix this
这个答案有帮助吗?
得分 3
2条评论:
I have this problem too and idk what to do.
完成的
conect your phone and headphones to the computer and turn on and off ur headphones couple times it will detect your phone .it happend to me and fixed it this way.i hope that help
完成的
添加一条评论
I have a samsung s6 and to fix I held to power button on the soundmine until it was flashing red and blue, then enabled quick connect on my phone.
Hope this helps.
这个答案有帮助吗?
得分 1
1条评论:
Hit "forget this device" and search for bluetooth devices again.
完成的
添加一条评论
Mine won't connect to my blu phone it keep asking for a pin code
这个答案有帮助吗?
得分 0
1条评论:
Try 1234 or 0000 those are default for most electronic accessories these days.
完成的
添加一条评论
My air raid sont connect to the bluetooth
这个答案有帮助吗?
得分 0
添加一条评论
In order to connect the Bluetooth-enabled Air Raid to your phone, Press the center button on the Air Raid. After making certain that the other audio device Bluetooth is on, the LED light should flash a blue light once every 5 seconds as long as the Air Raid is connected.
这个答案有帮助吗?
得分 -1
2条评论:
If you want to write a guide it would be welcome. This is not the way to do it.
完成的
you can go to Skullcandy Air Raid Troubleshooting for more help troubleshooting
完成的
添加一条评论
添加你的答案
Sasha Nevin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 58,120
