跳转到主内容
The Skullcandy Air Raid is a wireless portable Bluetooth speaker released November 15th, 2013 which streams music from any Bluetooth-enabled device.
16 个问题 查看全部
Why do the speakers of my device sound distorted?
My Air Raid sounds choppy, the music cutting in and out every few seconds. How can I fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Make sure that only one device is connected via Bluetooth to your Air Raid. When one audio device is connected to the Air Raid, and another attempts to pair with the Air Raid, it may result in choppy audio. Normally this should only last for less than 30 seconds. You can also reset the paired device list by holding Volume + button and the center button for 5 seconds. To completely “forget” audio devices and start fresh simply go into the pairing settings on your streaming audio device and remove the Air Raid, then pair again. If your speakers continue to sound distorted, they may have permanent damage. A replacement guide is available for you to fix your Air Raid.
这个答案有帮助吗?
得分 1
2条评论:
you can go to Skullcandy Air Raid Troubleshooting for more help troubleshooting
完成的
Perfect, my Soundmine was being a dink but it was because my phone was competing with my laptop for Bluetoothiness!
完成的
添加一条评论
You may need to clean it?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sasha Nevin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 1,688
