跳转到主内容
4-1/2" (115mm) model, D28110
3 个问题 查看全部
Is a torn power cable something that I need to address?
The rubber cable casing has broken/torn. Is this something that needs to be replaced? Can it lead to further problems?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
I wouldn't risk it. The part is $12.38 here: http://www.ereplacementparts.com/power-c...
这个答案有帮助吗?
得分 2
添加一条评论
A torn cable can impede the electrical connection to the power source, and it could also be very dangerous. The tear will affect the power flow through the cord, and it could cause extensive heat damage. You should replace the cable.
Also take a look here for troubleshooting the angle grinder.
这个答案有帮助吗?
得分 0
添加一条评论
Torn or cut power cables pose a shock hazard. They are really inexpensive to replace and easy if you have a screwdriver. This is a no-brainer.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrew 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 222
