Why isn't my mouse/trackpad working properly?
My trackpad left clicks when I right click and viceversa, and tracks my finger poorly, how do I fix this??
This could be either a software issue, which can be solved by downloading the proper drivers. If this doesn't fix it then you have a hardware issue and you will physically have to replace your mouse. Check out our trackpad replacement guide if this is the case.
这个答案有帮助吗?
It's probably a software (driver) or hardware (problem with the trackpad) issue. You should check out the troubleshooting guide for this device. It sounds like it would be able to answer your question!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 515
