跳转到主内容
February 2009 / 12.1 Megapixel / 3.0-inch pivoting LCD / 24x NIKKOR ED glass lens
Why doesn't my camera's flash work anymore?
I mainly only use my camera to take pictures and the flash would work perfectly fine, but once I switched over to the video setting the flash stopped working.
When I first started taking video, the flash would not come on at all and after a couple attempts to get the flash working, I switched back over to Auto and the flash still won't turn on.
Before I switched over to video, the flash was working just as it should. I've had my camera for a while; do I need to replace the flash bulb?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
已选择的解决方案
Unfortunately, the flash mode is not available when in video mode, only in Auto scene modes. As for switching back to Auto mode to test the flash, your battery may have been too low to function. The flash needs an ample amount of battery in order to work, so try recharging your P90's battery. Here is the troubleshooting page for any other problems you may encounter.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Brittany Berlanga 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 4,256
