跳转到主内容
Released in 2014, identified by 11.6 inch screen, 2-in-1 convertible touchscreen laptop. Model number 11t-n000.
23 个问题 查看全部
How do I find my model number?
I am not sure this is the repair guide for my laptop. Where can I find my laptop's model number to make sure I'm on the right page?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
已选择的解决方案
The laptop must be off.
With two fingers hold down both the Fn + Esc keys on the keyboard.
Press the power button.
This will give you a menu.
Press F1 for System information.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
If your laptop's model number are not clearly labeled on the laptop itself, the simplest way to obtain the model number is to press the fn + esc keys on the keyboard. This command should open up the HP System Information window which will list the product number of your laptop.
这个答案有帮助吗?
得分 4
2条评论:
Fn + esc does nothing whatsoever on mine.
完成的
fn escape doesn't do a thing
完成的
添加一条评论
Hey! sorry for the late response, but on the HP x360 laptops the model number is in REALLY small print on the back, not the back of the screen, but the bottom of the computer where it says "Made in taiwan" or "made in china" or whatever.
这个答案有帮助吗?
得分 2
2条评论:
Thanks! This is really helpful!
完成的
You rock buddy!!! I was SO frustrated because everyone makes everything so complicated. I come along your post and BAM there is my answer. Simple, Quick, and straight to the point!!! You are amazing.
完成的
添加一条评论
Just click on fn key and escape key at the same time
这个答案有帮助吗?
得分 0
2条评论:
that does not work on my laptop
完成的
it did not work for my hp pavililon but thank you for trying your best to help me
完成的
添加一条评论
添加你的答案
Natalie 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 19
过去 30 天: 50
总计 17,592
