跳转到主内容
Released in August 2014, the Lenovo Y50-70 Touch is part of the Lenovo's Y series of laptops. Equipped with a dedicated graphics card and a 15.6" touch screen, the Y50-70 Touch is specialized for gaming.
36 个问题 查看全部
Why is my computer is running slow when gaming?
My computer runs slow when playing graphics intensive games. Symptoms are a low fps, and a lot of lag. I'm sure that the problem is not my internet connection, but is with the computer. How can I fix this? Do I need to upgrade my graphics card?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 13
6条评论
how can it be a Lenovo Y70 lag reach i play gta 5th but it does not do the time
完成的
I have my Nnw Dell Inspiron 15 7000 series ..
It has 8 GB RAM,4GB Nvdia 940 MX and It is processing on i5 8th gen but it is not able to play igi pat 1 smoothly it always lags ....
can you help me why it is happening..??
完成的
i have asus tuf gaming it has nvidia gtx geforce 1050 and i7 8th gen. why when i play apex it’s so lag
完成的
some problem here,i downloaded for game with the capacity of 219mb but it was slow,what can cause the?and my memory is 2GB and am using a windows 10
完成的
I play Games on my Chromebook but I have a lot of free storage on my Chromebook but it lags WHAT IS GOING ON?
完成的
显示更多的1条评论
添加一条评论
4个答案
已选择的解决方案
I would check your memory first, If you can increase it.
You also may not have enough free space on your HD. Use the HD tools Windows has to clean things up.
这个答案有帮助吗?
得分 5
3条评论:
Actually they need a whole new Rig. This is designed for novice gamers, with modest gaming capabilities. But, yes get the background processes & programs down to free memory. I always run a gaming rig with a stripped down operating system to free up resources. However, this does have 2 graphic processors: An Intel 4600 and the Nvidia GeForce GTX 860M GPU with 2GB of VRAM. It could just be a setting in the operating system or graphics driver software not kicking in the Nvidia.
完成的
So for a person who doesn’t play too many games, what would be a good way to get better performance out of the computer without breaking the bank?
完成的
Cam, If you have a HDD how about upgrading to a SSD if you've already upgraded the RAM to the max.
完成的
添加一条评论
Problems that plague gaming laptops include overheating, programs running in the background, and the graphics card not running at the required speed (usually in MHz) for the game you are playing.
In order to avoid overheating problems, you may want to replace the fan(s) with better performing ones or give your laptop a rest and let it cool down.
In order to prevent programs from starting up while you are playing a game, manually go into the program (settings) and either turn off the program or schedule it to run while you aren't gaming.
In order to see if your graphics card is causing lag, look at the game requirements on the original packaging. Compare to the one running in your laptop. If the graphics card you have doesn't perform at the recommended capacity then you may need a better graphics card.
这个答案有帮助吗?
得分 3
1条评论:
@Kevin, You're spot on the performance issues many newer games require. Sadly, there is not much you can do to make a laptop into a gaming box. It is what it is.
完成的
添加一条评论
Check your Energy manager during the games make sure the performance setup is on the highest level.
这个答案有帮助吗?
得分 2
1条评论:
Totally forgot about this. Thank you!
完成的
添加一条评论
I have had the same issue. it's not the GPU. it's the CPU's being throttled due to overheating.
there's a membrane on the back panel that's there to filter out the dust in the air. after using the laptop for a few months it became blocked with all the dust and was practically impossible to clean.
i just removed it today and already idle temp is 14-18 degrees lower.
during playing a game even like Dota2, 10-15 minutes into it CPU reached 100 degrees. so naturally, the speed is throttled so that it doesn't burn out.
i'll try the game later and see if i have any improvement
这个答案有帮助吗?
得分 0
1条评论:
I have tested this and it reduced my max temp from 100 = throttle to 72. screw that terrible dust screen and throw it out. just dust out your laptop every now and then with compressed air and bob's your uncle
完成的
添加一条评论
添加你的答案
Nicholas Hardy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 125,127
