My iphone 6 has been bent and bent back twice. Cellular service worked fine untill recent smash of the phone (throw it to the wall hardly), and the two volumn button area bent again. After I opened the case, and bent the area back, the cellular service failed. it continueously displaying searching for network.
Here is a few things I have tried, which sometime works, and not work.
1. contact ATT to reset the network login from their side. [looks like the most useless one. sim chip are very standard, and robust, shall not be the problem].
2. wipe out the phone and restore it from back up. Remember to back up your files on your computer before wipe out it. [worked for the first two times, last for one day. then back to searching again.]
3. Tighten the vibration module screws. In one attemp to bend the phone, I notice the right screw to tighten the vibration module on the phone is falling out, and I screwed it back. Restore the phone, and it works out nicely for a day before it failed out again.
4. Tighten all the screws on the two volumn button area, and top left area. The cellular service comes back for two days. before it start loss it again.
5. Always try to Push home and power button at the same time to restart the phone, while your phone displaying searching for cellular network. It is a hard reboot, and will reset some software setting for network searching.
Conclusion:
In my experience of my phone, it looks like the bend issue of the phone will cause some parts to disconnect internally. Most likely is the two cellular antennas: one on the top left, and one at the bottom right. Also, if you use the phone vibration a lot, then after a some time, the screw tighten the vibration module is lose. This will cause the bottom right antenna disconnection as well.
while your phone have cellular service, type *3001#12345#* in the phone call dial panel. it will direct the phone to field test mode. You will see how your phone behaves while connecting to cellular network.
47条评论
I dropped my phone as the others suggested. It worked.
由 jeffrey 完成的
Lost network signal, keeps on searching
由 Raju matharu 完成的
Yoooo this dude down here got it straight. Turn your phone off. Take the sim out. Blow on the sim, and then blow into the sim port. Turn it back on after you put the SIM card back in. Wahhhh bammm. Presto. Blow on it like an old video game card.
由 Jordon 完成的
I had this problem recently. The fix was hard to find. But I managed to fix it.
No signal whatsoever. When bending the phone (it actually was a little bit bend) signal came back for a minute or a week. A repair shop told me I needed to replace the complete back housing. Price: 180 euros! I couldn't believe the problem was the back housing but more likely a dodgy connection. I ordered the tools to open the phone. At first I couldn't find anything after checking various components (wifi cables, docking antenna or whatever that all was). The second time I opened the phone, I found that a little soft pad that looked like it has melted from its place. It supposed to stick to the antenna cable exactly below the ear speaker, and the lcd unit pushes this cable down, probably making electrical contact somewhere. After closing the phone it kept searching for a network for a day. But after a reset the carrier was back! This also seemed to be a common problem. So be sure to reset the phone!
Hope it's useful to someon
由 titotyfus1990 完成的
titotyfus1990 i have the same problem but what soft pad melted ? can you help me ?
由 xristosxristou97 完成的
显示更多的42条评论
