跳转到主内容
The first tablet from Acer's Iconia Tab B1 family, Acer Iconia Tab B1-A71 was announced in January 2013.
21 个问题 查看全部
Why the screen show White?
My Acer got white!! I was just playing some music, then i lay it down on the couch and went for something. When i returned the screen has got white and there was a crack in The middle, (not really, but it looked like an inside one ). But there was a black spot too. I turned it off and it turned black. Then i again turn on, but the screen appears as white ,black spot,and crack as it was. I tried to pull the notification bar. A sketch of bar appears but no icons or nothing. Help me please.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Did you sit on your tablet? Or did it drop when you were away? Anyway, the fact is your tab lcd display was damaged.
这个答案有帮助吗?
得分 2
2条评论:
SO, should i have to change the lcd screen? And my sister was there too, according to her, the tablet was there laying, and it didnt even fall. She haven't lied. However, what to do with the tablet, and how to fix it??
完成的
You mentioned that your tablet had cracks, spots and blank screen, these are all hardware issues not software issues. A replacement display can fix it. If you'd like to DIY repair it, this is the part: http://www.etradesupply.com/acer-iconia-... and this is the guide Acer Iconia B1-A71 LCD Display Replacement
完成的
添加一条评论
I have the same problem but my screen was already cracked
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Asad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 6
总计 2,425
