跳转到主内容
Acer Iconia B1-A71 LCD Display Replacement
你所需要的
视频概述
  1. Acer Iconia B1-A71 LCD Display Replacement, Acer Iconia B1-A71 LCD Display Replacement: 步骤 1 中的图像 1,3 Acer Iconia B1-A71 LCD Display Replacement, Acer Iconia B1-A71 LCD Display Replacement: 步骤 1 中的图像 2,3 Acer Iconia B1-A71 LCD Display Replacement, Acer Iconia B1-A71 LCD Display Replacement: 步骤 1 中的图像 3,3
    • Switch-off the tablet.
    • If you can't switch it off, use the reset button to do this.
    • With a cutter and a plastic tool remove the back cover.
    • If you have a memory card inside, don't forget to remove it!
  2. Acer Iconia B1-A71 LCD Display Replacement: 步骤 2 中的图像 1,2 Acer Iconia B1-A71 LCD Display Replacement: 步骤 2 中的图像 2,2
    • First, disconnect the battery.
    • Now, disconnect the loudspeaker and remove the back cover.
    • Remove all scotch tapes and disconnect the touch screen flex cable...
    • LCD display flex cable,
    • the microphone,
    • and the WiFi and Bluetooth antennas flex cables.
  3. Acer Iconia B1-A71 LCD Display Replacement: 步骤 3 中的图像 1,3 Acer Iconia B1-A71 LCD Display Replacement: 步骤 3 中的图像 2,3 Acer Iconia B1-A71 LCD Display Replacement: 步骤 3 中的图像 3,3
    • Unscrew 5x screws and rmove the main board.
  4. Acer Iconia B1-A71 LCD Display Replacement: 步骤 4 中的图像 1,3 Acer Iconia B1-A71 LCD Display Replacement: 步骤 4 中的图像 2,3 Acer Iconia B1-A71 LCD Display Replacement: 步骤 4 中的图像 3,3
    • The battery is glued to the LCD display metal shield with a double sided adhesive tape.
    • Use plastic tools and carefully remove it.
    • Remove all tapes from the LCD display metal shield.
  5. Acer Iconia B1-A71 LCD Display Replacement: 步骤 5 中的图像 1,3 Acer Iconia B1-A71 LCD Display Replacement: 步骤 5 中的图像 2,3 Acer Iconia B1-A71 LCD Display Replacement: 步骤 5 中的图像 3,3
    • The LCD display is held by metal frame and some locking clips on it.
    • Use a cutter and a plastic tool to separate the LCD.
    • You have to work slowly so as not to break the display.
    • Now, install the new LCD display and reassemble the tablet.
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
结论
6等其他人完成本指南。
ZFix
于12/09/13注册
191,308 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,539篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 11,032
