跳转到主内容
加入维修社区 - 创建账户
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Fan is running constantly
Hi,
I have a mid 2012 15 inch Retina Macbook Pro that was running absolutely fine till last 2 years. Just recently it is creating problem like the fans of the laptop run constantly even under normal cpu load and temperature. I have tried every possible guide and way to fix it but just couldn't solve it.
Then I ran the hardware test and found out the following error:
4SNS / 1 / 40000000 : Th2H - 127.875
After little bit of googling, I found out the error code referred to sensor related problems. Important to mention here, I live in Bangladesh where apple does not have a direct store but 1 - 2 authorised retailers and service providers. So I took my laptop to one of the authorised service providers w/o any delay and they told me I have to change my logic board as there's no other way to fix it. And changing the logic board will cost me hefty usd 1200 approximately which is a lot for me.
So can anyone suggest me what to do now. Is the error code really refers to replacing my logic board? Is there any way to skip the replacement? I mean is there any way to control fan by any app? What best I can do now?
I will highly appreciate if anyone gives me an honest opinion.
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Thanks for the ellaboration. But what is the solution for this? Do I really need to replace my logic board? Please do suggest.
完成的
For now please un-accept my answer until we hear from Old Turkey on a possible repair.
完成的
Hi oldturkey, even I can understand that I need to follow through Apple, but does that heat sink problem really refers to replacing my logic board? Thats all I have been asking to find out whether my local Apple authorized service providers are giving the right solution or not. Another thing, if I can't get help from Apple (which is more likely possible since I can't travel with it to another country), then what would be the option for me to survive with this machine? How about ysing the mac fan control app to control my fans since the temp sensor can't seems to control it anymore due to the sensore failure? Plz help :(
完成的
添加一条评论
3个答案
最有帮助的答案
What you need is a "Flat Rate Repair" from Apple. It should cost about $320 US. plus some shipping. Since you don't have an Apple Store in Bangladesh, I would call the one in India, here: India
(91) 1800 4250 744
Let us know if this fails and some of the guys on this site might be able to figure out a work around.
Here's the numbers for Apple around the world: http://support.apple.com/en-us/HT201232
这个答案有帮助吗?
得分 2
4条评论:
+ Most likely the best solution. I would not have thought about sending someone to a near by country for service, something for me to add to the grey matter between my ears.
完成的
Thanks for the suggestion. Apple india would also ask me to bring in the laptop by myself. But what I am asking from all of you specialists is really replacing logic board is the only solution for the problem? If I use mac fan control app and try to control the fans would that be a problem for the laptop?
完成的
Ahmed, I live 300 miles away from my nearest Apple Store. There is an Authorized Service Provider in my city which I seldom use except for warranty service as they are my direct competitor. Apple allows me to deal directly with them. The Books get shipped 520 miles (837 KM) away. I think you are assuming that you would be required to bring it in yourself. Who cares how it gets there? Ship it to me and I'll send it to Apple, the extra shipping would probably cost about $110. I FedExed one back to Macau last year for $55.
完成的
Thanks mayer, I'll take ur advice and will call the apple india as the authorized service center here in my country is only suggesting no other way but to replace the logic board. I'll reply to u here as soon I get a response from Apple india.
完成的
添加一条评论
1st off I would suggest following Mayer's advice. His advice is the correct and safe way to solve your problem. If that is not possible, no, replacing the logic board is not the ONLY solution. Using a "program" to adjust the fan speed may be a solution, although it still may cause kernal panics or other problems. All these sensors talk together and communicate with the SMC. There is a risk of causing further problems by not doing things "the Apple way". There could be more than one issue causing the fault code, the fault codes are derived by a triangulation of multiple sensors. Sometimes a faulty temperature "error code" can actually be caused by an incorrect voltage reading on another part of the board and/or other things. Try a program that corrects the fan speed and monitor your system logs. Let us know the result. Information helps us, help others, at this point you are one of the others.
这个答案有帮助吗?
得分 1
添加一条评论
IF you want to use a fan control app, I use SMCFancontrol.... Works great.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ahmed 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 12
总计 4,909
