跳转到主内容
第三代配备 Wi-Fi 的 iPad,于 2012 年 3 月 16 日发布。型号A1416。维修需要加热并小心撬开它。
not charging when plugged into wall, but charges from computer
My iPad won't charge when plugged into the wall charger. However, it will "trickle" charge when plugged into the computer. I tested both the charger and the cable with another iPad and the second iPad charges just fine using that wall charger and cable. Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
This happened to me and I found a SOLUTION!!! On a whim, i tried to used my sisters “ultra fast charger” for her Galaxy note 10 and it worked!!! It’s the only charger that works. I ordered one off of amazon(not a samsung branded charger) and thankfully its been working great.
完成的
添加一条评论
1个答案
已选择的解决方案
Has your iPad been repaired/manipulated from the inside before? Dropped? Water damaged? Have you been using a cheap charger? Answer those to help figure out the issue.
Otherwise, here's a troubleshooting guide for the most common issues:
1- The charging dock could be A/dirty or corroded, B/unseated due to a drop, C/Damaged:
1-A/ Gently clean the charging dock (where the charging cable connects) with a tooth-brush dipped in 90%+ isopropyl alcohol while iPad is off.
1-B/ Be warned that you could easily break the glass for this one: use this guide to open the iPad. Look at the battery. Is it swollen? If not, unseat the connector, clean it with IPO and a toothbrush if you like, then re-seat it and test. If battery is swollen, it could be that the battery is acting out. You will need to replace it.
1-C/ Try a new charging dock.
2- The data and/or power management circuit on the logic board could be acting out due to a number of causes such as those mentioned at the beginning. I had a similar case where that circuit was damaged and the iPad would charge from the laptop but not the wall charger.
这个答案有帮助吗?
得分 4
3条评论:
Thank you for the great suggestions... I cleaned the dock connector with 90%+ isopropyl alcohol and it solved my problem.
Thanks again for your help.
完成的
Please accept the answer then to close this case. Glad it worked!
完成的
My i paid water damage now battery finish i open and wash and heat but now when i contact charger it's processor heated please solution
完成的
添加一条评论
添加你的答案
vakeit 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 90
总计 13,624
