跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Battery will not charge
I replaced the broken screen/lcd on my wife's phone and it all works fine except the battery will not charge. the charging symbol comes on and the phone beeps when you plug in the charger connector. the battery was perfect prior to the screen repair. I cleaned as i reinstalled with IPA on all the electrical contact points.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Did you make sure to reconnect the battery connector to the logic board? The phone shows the charging symbol, but doesn't gain percentage? Is that what you mean by not charging?
完成的
添加一条评论
2个答案
已选择的解决方案
Try reseating the battery cable, then cleaning and reseating the charging dock connector and cable as well. If that doesn't help,
Examine the battery connector and around it on the logic board.
Also examine the charging dock connector and around it.
Do you see anything damaged, broken, missing, part removed from the board? How about the battery cable itself, is it torn in any way? Are the battery connector solder points broken?
这个答案有帮助吗?
得分 1
添加一条评论
You can at first try another battery, if that doesn't work check the battery connector (especially the middle 2 pins).
When it is at the charger, does it drop percentage or does it just not change?
You can also try charging it when powered off for 1 hour and then check again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
brendanoriordan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 25
总计 180
