跳转到主内容
The Satellite C660 is a series of laptops released by Toshiba around 2010. They have 15.6-inch screens and a variety of Intel processors.
20 个问题 查看全部
My laptop not showing anything on display.
My laptop cannot show anything on the screen and the fan is not spinning but the power-led is on. What is the possible problem of this.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
5条评论:
try an external monitor first and see if it shows anything.
完成的
Same problem. Black screen, no sound but fan noise. Both leds green.
I hope mobo is still alive. I'll try to reset BIOS removing little battery.
完成的
Try re-seating the Memory. If the fan is spinning up abnormal loud try to re-seat the Cpu.
完成的
I have the same problem. It powers up with a blank screen, fan goes on, then suddenly it powers out.
完成的
Ditto here. I see the fan is not spinning because I took the keyboard out. I have removed memory, HDD, plugged into external monitor... nothing.
完成的
添加一条评论
4个答案
My screen is blink nothing showing
这个答案有帮助吗?
得分 0
添加一条评论
My screen is black and I do not have a fan sound
这个答案有帮助吗?
得分 0
1条评论:
Ditto! I have pulled out the memory, HDD, keyboard, hooked up to external monitor and nothing. When I power on, I get two LEDs on in the front, but I can see the fan doesn't move (because keyboard is removed). I am going to replace CMOS batt... maybe that is the problem?
完成的
添加一条评论
My laptop says reboot reboot
这个答案有帮助吗?
得分 0
添加一条评论
toshiba motherbore c660 gone what can i do to reply it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kellin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 2,834
