跳转到主内容
加入维修社区 - 创建账户
Charging dosn't work for phone
My acer liquid e3 doesn't charge and its not the charger
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
not plone a &&^&^$^ truck
完成的
Please 🙏🙏 help me I need your help please listen me properly
完成的
添加一条评论
2个答案
已选择的解决方案
1/ Not the charger?
Ok,
2/ Not the cable?
3/ The wall plug/adapter if any?
4/ Is your battery accessible? (I think for the Acer E3 it is)
5/ Can you visually inspect it to see if it is swollen? (I think you can inspect it) => swollen = bad, may not hold charge, replace it.
6/ Will your phone turn on and work if connected to the charger with the battery removed? => replace battery and try again to see if new battery will hold a charge.
If you rule out all of the above, let us know to investigate further, as it could be the charging dock (where the charging cable plugs into the phone), or something wrong on the logic board, etc.
这个答案有帮助吗?
得分 3
2条评论:
maybe your battery have been over used so it may drain
完成的
im having the same problem, tried replacing battery but still no joy. It wont turn on neither. I did drop it beforehand but also the battery hasnt been lasting long at all before it happened. please help itsmy work phone and im loosing business.
完成的
添加一条评论
i put it on change and it keep on tuurn on then off
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Taras 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 6,498
