跳转到主内容
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
Replaced LCD, now LCD not getting power
I have 2 iPad2s that I'm replacing the LCD and digitizer. One repair went fine but the other has an issue where the LCD won't get any power from the iPad. I plugged the iPad into iTunes and did a restore but there was no change (it does get power). I tried the LCD and the LCD flex cable in the other iPad2 to make sure they aren't the issue. The LCD And flex cable work fine in the other iPad. Tried cleaning the LCD connector on the logic board...no go. Not sure what to try next!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi Kyle,
Since you are sure the LCD is in good working condition, then the problems lies on the logic board of the iPad 2, such as:
- The iPad 2 is not producing any image.
- An image is produced but there is no back-light. Usually the back-light filter needs replacement. If back-light is the issue, you can see a very "dark/faint" image on the LCD if you look very carefully.
- It could be that the LCD connector on the logic-board is damaged. Examine it using a magnifying glass. Look for broken/corroded pins, anything damaged/missing/part-removed. Look also around the LCD connector.
- If someone worked on this iPad before, it could have had this issue from before it landed at your desk!
- It could be that the drop or whichever damaged the screen also caused damage to the logic board.
- Could be ESD damage from your or previous repairs.
- I am assuming that the iPad is detected by iTunes when connected to a computer, meaning the image/back-light circuits are damaged. IF the iPad is not detected by iTunes, it could be that the logic board is "dead" or unable to charge and communicate with a laptop. In that case, you have a different set of trouble-shooting steps that you can follow to determine if the issue is with the board or the charging dock for example.
If you are certain the logic board is damaged, you'd better refer this iPad to someone with the tools and the ability to trouble-shoot and repair an iPad's logic board.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Had this trouble with a lcd in an iPad and it would not power up and it was the graphics chip it needed resoldered
这个答案有帮助吗?
得分 1
1条评论:
Ah, thank you...that makes sense.
完成的
添加一条评论
添加你的答案
Kyle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 102
