跳转到主内容
Repair information and troubleshooting for the Dell Latitude E6230 business class laptop computer. This laptop has a 12.5 inch screen, and was announced in May 2012.
15 个问题 查看全部
Laptop freezes after waking from hibernation or sleep?
for the past few days, when i wake up my computer from sleep and hibernation mode it'll freeze and the only way tp get it to work is to hold the power button.
just for your information, i recently updated some drivers but i will try to delete the new power management driver and go back to the old one
Edit: i cannot roll down battery driver for some reason
回答此问题 我也有这个问题
这是一个好问题吗?
得分 43
75条评论
Brothers , just go to
1. "Device Manager"
2. "Storage controllers"
3 . Right click on "O2Micro Integrated MMC/SD controller" and disable this driver.
Your Welcome!
完成的
Thanks alot brother (Y)
完成的
I was having the same issues with my Dell latitude 5420... But with the steps above I was able to stop it... Thanks Alot...
完成的
me too, same issue with Latitude E6430 and the above steps solve it. Thank u very much
完成的
Wow...Thank U Thank U it worked for me
完成的
显示更多的70条评论
添加一条评论
5个答案
最有帮助的答案
It's one of the card readers, just disabling it fixed the issue for me
这个答案有帮助吗?
得分 9
9条评论:
what is the card reader?
完成的
thanks much bro... you made my day and I have solved the problem which bothered me almost two months ..I changed the window almost thrice times but the problem still existed till today i got ur help...thanks much...
完成的
1. "Device Manager"
Your Welcome!
完成的
Thnx bro, worked for me also
完成的
Thanks a lot bro i too resolved by this problem
完成的
显示更多的4条评论
添加一条评论
1. "Device Manager"
Your Welcome!
这个答案有帮助吗?
得分 3
2条评论:
Zabihullah Xabih  thank you. In my computer I have not option “O2Micro Integrated MMC/SD controller”, but I check another similar things. In my computer (M4800) the problem is option “ ControlVault decive”. Click on it and choose “Disable”. And computer works perfectly (without freezes after waking). Thank You! You helped me to find solution! :)
完成的
Even I changed the OS from Windows to Ubuntu and CentOS but still I’m getting the same issue and many of the users are complaining the same thing on Dell E7490. It seems some hardware issue not OS issue If we lock (Win+L) the system It's happening Hence, we are turning of the monitor instead of it. Any solutions would be appreciated. Thanks in advance!
完成的
添加一条评论
Same issue here (caused by the Dell O2 card reader driver A04).
Edit: the A02 revision of the above driver causes the same issue.
This issue occurs in Windows 7, 8, and 10.
I fixed it by uninstalling the Dell O2 card reader driver Rev A04 and then installing the Lenovo equivalent driver from here:
http://support.lenovo.com/gb/en/download...
This covers Dell Models
E5530
E6430
E6530
And probably any other Dell laptops with the O2 card reader driver.
这个答案有帮助吗?
得分 2
添加一条评论
This is indeed an O2 Micro driver problem. Delete it from Device Manager. It will ask if you want to delete drivers, and say yes. Rescan for hardware change, and let Windows 10 install default SD card reader drivers. This will allow you to still use the SD card reader and put the laptop to sleep without issues.
这个答案有帮助吗?
得分 2
添加一条评论
Reinstall OS it help me with freezing while going to sleep
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
V_S 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 38
总计 51,619
