跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Green Pixelization on replacement screen
Hello,
I've fitted a new complete screen and digitiser and am getting green shadowing on grey backgrounds, please see images.
Do you think it's my fitting or a faulty replacement?
Besides this the screen works perfectly.
Cheers, Guy.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You *most* probably have a defective screen or some issue with your connectors and connector cables.
I would go through the following to rule out some of the most probable causes:
- Disconnect the 2 display assembly cables, clean the connectors with a cotton swab dipped in 90%+ isopropyl alcohol. Then reseat the cables and test the phone.
- If the issue remains, re-install your old screen.
- If you don't see this anymore then the new screen is defective and that's very common. But to be on the safe side, check the 2 display cables for an abnormal crease or tear. If you see any of those, you may have damaged the screen cables during the first repair attempt.
- If the green hue appears also on your old screen, you may have damaged something on the logic board during the first screen replacement. If that's the case (although I doubt it), let us know and we'll take it from there. OR you are repeating the same installation mistake with regard to the display cables (tearing or creasing them).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
guyrwsmith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 72
