跳转到主内容
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
254 个问题 查看全部
问题已关闭
Can I use DDR3l SODIMM modules?
Can i use a DDR3L modules for my IMAC?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Yes - That is what OWC is selling.
If this answer is acceptable please remember to return and mark it accepted.
这个答案有帮助吗?
得分 1
1条评论:
And that's the answer! Thanks!
完成的
添加一条评论
Standard RAM: 8 GB Maximum RAM: 16 GB*
RAM Type: PC3-12800 DDR3* Min. RAM Speed: 1600 MHz
Details: *8 GB of RAM is standard and it can be upgraded at the time of purchase to 16 GB for an additional US$200. Although Apple does not intend for one to upgrade the RAM after purchase, and doing so is difficult, it is possible. Look at the installation procedure before you go ahead. I'm doing one today and it's a PITA. My customer also wanted a mSATA card installed but only Apple makes one as of this data and Apple wanted $950 for the 256 and $1350 for the 512K. All these slots are on the back of the logic board which requires removal to install.
Here's how to do it: iMac Intel 21.5" EMC 2638 RAM Replacement
这个答案有帮助吗?
得分 1
2条评论:
This is not the answer for the question i asked. I wonder if i can use low voltage DDR3L eexcept of ordinary DDR3.
完成的
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 237
