跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2201 个问题 查看全部
Microphone not working when speaker is on!
Hi All,
After changing the screen of my iphone 4s, everything is working except when I use the microphone when the speaker is on.
I think i've a bad contact because i heard some noisy sound.
Do i have to check cable ?
Do i have to change a piece ? which one ?
Thanks for your help
Benoit
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi Benoit, Yes sir it looks like your going to need to change a cable. If the microphone is not working when speaker is on, then check for damage to volume headphone jack flex.This flex cable also has a microphone attached to it. This cable is probably damaged and needs to be replaced.
Heres a link to the guide to replacing that flex cable:Here
& Heres the part link so you can buy the part.
Hope this works for you my friend!
Good Luck!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Benoit 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 12
总计 148
