跳转到主内容
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 个问题 查看全部
Replacement screen wont light up when mid frame is fitted
I recently replaced a cracked screen in a friends Galaxy S4. When I first put the phone back together I thought the new screen was faulty as the phone would turn on but the display wouldn't light up. After some fiddling around I tried turning on the phone while I had the mid frame removed and to my surprise the screen worked just fine. Upon re-installing the mid frame the screen stopped working again. I removed the mid frame once more, turned the phone on and then began to snap the display assembly back into the mid frame. Everything was fine until I snapped the display assembly and the mid frame together around the top left corner near the volume button at which point the screen cut out. Does anybody know of a way that the screen could be shorting out? Or could it perhaps be pressure on the digitizer flex cable? Any assistance would be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Hi, did you ever find a solution to this as I have exactly the same problem.
Kind Regards,
Danny.
完成的
添加一条评论
2个答案
I faced the exact same problems with my new brand new s4 module from a official Samsung dealer. I could secure the whole frame, but once i secured the right top part of the midframe (looking from behind) it would short out and not even boot the whole phone anymore.
The phone was a i9506 and the module a i9505.
I am not sure if this has anything to do with it, but i do know what caused it.
When i taped off the black screw securing the motherboard right under the part of the frame that shorts the display the whole problem went away.
I tried it without the black screw and it also does not short out.
I believe the black screw helps alot with positioning accuracy from your GPS, so if it is not a solution to leave out the black screw for good, u will have to kapton tape it.
To make it a little bit more clear, i am talking about this black screw:
Good luck! :)
这个答案有帮助吗?
得分 0
添加一条评论
Not sure if this will help. But I had same problem and I then relized I had ordered frames for verizon/Sprint and there just enough difference between them and T-Mobile/AT&T to make it not sit right and it actually power switch causing problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tom Burridge 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 4
总计 476
