跳转到主内容
加入维修社区 - 创建账户
iPad Air Wi-Fi + Cellular,型号 A1475。有深空灰或银色可选,提供 16/32/64/128 GB 配置。
iPad Air behaving erratically: "ghost touching" after screen replacement?
Usually, but not always, the replaced screen starts to behave erratically a while after installation. Immediately after screen replacement it works fine, but during the same day it starts to have these "ghosting" problems. The funny thing is that not every screen have this problem. I have been wondering what can cause this problem. Does the adhesive "let go"? Two screws at the top of the screen has a black protection sticker. I have tried to skip them and to keep them but still it doesn't help. I have tried to be really precise when I remove the old adhesive from the frame. I have also tried a "so called solution" to tape the digitizer copperframe, still no good. I also use the old home button. Are my replacement screens bad quality or am I doing something wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
4个答案
solution to phantom/ghost touches ipad air
The following link is a fellow user of Ifixit who posted how to fix this issue.
If this has helped please score the fellow ifixit user and accept my answer.
Update
Unfortuantly i couldnt find anything, apart that when the screen was replaced, it may have affected some hardware/components.
If you have warranty take it to your apple store. If you have repaired it yourself the warranty is now void.
My solution to this would be a new screen replacement from apple themselves.
If this has helped please accept this answer
这个答案有帮助吗?
得分 0
2条评论:
The tape solution doesn't help.
由完成的
okay, give me a couple of minutes when i look for a solution
由完成的
添加一条评论
I hate the iPad air repair because of this ghosting problem! Even with the tape some iPads still have this problem.
这个答案有帮助吗?
得分 0
添加一条评论
Ok a Repairer in this forum said that tape should be applied to the ribbon and the wires.
这个答案有帮助吗?
得分 0
添加一条评论
Adidan,
Usually the taping needs to be done on the iPad mini. On the iPad Air it is faulty replacement screens. I have had 3 in a row sometimes, you can imagine how frustrating that is.
You can put the screen down before adhering and gently push around the edges without cracking the screen to see if there is any one area that triggers it.
Try and put on the old screen if it isn't damaged to much and see if it still is "ghosting".
If you have another iPad Air for testing you can test the replacement screens to see if they "ghost" on another device.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
adidan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 49
总计 11,325
