跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Bent frame and now digitizer issues.
My daughter threw my iPhone 5S at the wall and it cracked the LCD only and bent the frame pretty bad. I installed a new screen from iCracked and it wouldn't work properly. I popped it back out of the frame and it worked ok so the frame is putting too much pressure on the LCD for the touch to work correctly.
I bent the frame back as much as I could and it's straight now but the touchscreen is still acting weird. As soon as i turned it on, I could feel heat from the logic board from under the camera area. And the touch screen works sometimes and sometimes it doesn't respond in the same spot.
Bad screen? frame problem? I usually have non responsive touch intermittently in the upper right corner.
Everything works fine except the intermittent touch screen issue and the heat coming from the connector area on logic board.
Update
This is the only part that is bent now. It bent towards to rear of the phone right at the (-) volume button.
For example, when i swipe up on the settings screen, it will scroll a bit and snap back up while still swiping. Or I tap the Cancel button on the top right of the Messages app and it won't register at all. But the Camera app icon in the same spot, on the homescreen, will register just fine.
Update
So I carefully took my motherboard out and this fell out with it. Not sure what it belongs to but is it a ground for the frame?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
It sits at the top of the phone between the case and the motherboard just to the left of the camera. It sits with the flat edge to the top.
完成的
添加一条评论
2个答案
最有帮助的答案
Can you show pictures of the damage? you can buy tools that straighten the frame out but it's meant for bulk use really. Don't really know how it's bent without looking. If it's on the corners you can use pliers.
You can always considered replacing the case, you can pick them up for around $20/£12
这个答案有帮助吗?
得分 1
1条评论:
posted an update with a photo.
完成的
添加一条评论
I think i may be having the same issue. The corners of my frame are quite bent on the top and I think its starting to effect the digitizer. What do you suggest
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cody D 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 1,070
