跳转到主内容
加入维修社区 - 创建账户
BLU Life 8 是一款基于 Android 4.2 的智能手机。它配备了一块分辨率为 720 x 1280 像素的 5 英寸显示屏。
Why won't it charge?
My blue life 8 won't charge. The charging port looks fine. When I plug it in the charger . it will grab charge for 1 second. And then won't charge at all.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 15
1条评论
Do you have a secondary charger/ cable you can try? it may look fine but the pins wear over time.
由完成的
添加一条评论
8个答案
最有帮助的答案
The charging port tends to come unattached from the phone and needs to be fixed also my new phone the tips that you plug in some are smaller size so when you plug it in it won't charge but some have a tight fit which it means its a bet bigger and it fixed the problem you need to find the right charger even though there all the same type the may look the same but some are a tiny bit bigger which makes the perfect fit because the charging port tends to move around while charging it.
Sorry if I made any spelling mistakes.
-Ace
这个答案有帮助吗?
得分 2
2条评论:
Do you know where i can fix my phone Ace?
由完成的
We offer mail in repairs. www.gadgetifix.com
由完成的
添加一条评论
you may have a bad battery or you ned to replace the charging port
这个答案有帮助吗?
得分 0
添加一条评论
i have had mine for less than a month and having the same issue
这个答案有帮助吗?
得分 0
1条评论:
yea I think something is not done correctly with that model. mine stopped charging after a month and my husband's stopped working . I just got a different phone.
由完成的
添加一条评论
There are a few things that it could be. As others have said, it could be the battery, charge port, or cable. On mine, however, it was the charge circuit on the motherboard. Mine was refurbished, so it didn't have a warranty. So I opened it up and saw that the solder work was supremely sub par. There were about 3 or 4 diodes that were far enough away from the solder pad, that they eventually lost connection. It could have been from the board flexing or from heat. Either way, I added a big solder blob to anything that wasn't perfectly centered and it worked again. I am actually thinking about trading mine in for something else.
这个答案有帮助吗?
得分 0
2条评论:
I've had two Blu Life 8's. The first one had this issue (though mine was new), so I used the warranty to get another. It took them 3 months to send the second one and now it also has this issue. I for one, will not be buying another Blu product.
由完成的
me either sent mine back twice keps charge for the first day i get and doesnt charge afterwards
由完成的
添加一条评论
I've had my phone for over a week now....everything was fine until it went completely dead..…now its not coming on at all
这个答案有帮助吗?
得分 0
1条评论:
Bad connection to the battery or the circuit bored is broken or the screen is broken or you just bought a cappy phone
由完成的
添加一条评论
I had one that I had to return after only 3 weeks. It went dead and would not take a charge. Now the 2nd one I have is not charging completely and loses it's charge fast when taken off the charger. This happens whether I'm using the phone or not. On youtube I found a video that said to try cleaning the port. I'm in the process of trying to carefully do this. Actually it feels like the port may somehow have become loose. I think it has a few problems going on with the port as well as the battery.
这个答案有帮助吗?
得分 0
1条评论:
It's the battery and or its just a crappy phone
由完成的
添加一条评论
My blue life x8 wont charge,even if the technician replace the charging pin a new one..but still wont charge.please help my problem..thank you.
这个答案有帮助吗?
得分 0
2条评论:
Replace the circuit bored not just the charging pin
由完成的
And or the battery
由完成的
添加一条评论
same thing heppened to me, the "flex" does not make sufficient contact with the charging port, you should put a small piece of cardboard underneath to press it
https://www.youtube.com/watch?v=nDKbUGZ-...
这个答案有帮助吗?
得分 0
1条评论:
Yeah but but card boRd can catch on fire not the best place to be shoving cardboard in it evan though it may work.
由完成的
添加一条评论
添加你的答案
karen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 7,780
