跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
iPhone 4s heating at the processor
I had went in a water park and sealed my iPhone in a water proof bag which turned out not to be water proof at all.
As i took out the iPhone from the bag fulled with water i noticed the light was blinking and the iPhone screen went blank. I tried booting up back the iPhone but was of no use.
I opened the iPhone and dried out the inside and as soon as i connected back the battery connector i realized that where the processor is located it started getting hot.
Very hot after about 3 minutes
I don't know what i should do at this moment
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Surely the water park is to blame here?
if they claim the device is safe in the big then it is clearly not and you can take action against this. Something tells me there will be a smallprint somewhere though defending them in case this happens.
完成的
添加一条评论
2个答案
已选择的解决方案
First--I love the title of this question.
I tried booting up back the iphone but was of no use.---this was a mistake. know better next time. mixing water and electricity is a bad idea.
What next? Open it up, take apart all of the components and clean with alcohol and a toothbrush. Dry it, get a new battery and see what you have.
Heat = a short. There is a small chance that the short could be relieved with the cleaning, but probably you have component level damage. This is usually a big easter egg hunt and rarely worth it.
jessa
这个答案有帮助吗?
得分 1
7条评论:
So whats should i do change the logic board?
I looked for he logic board through out the internet and didn't find any. Any help?
完成的
I would use 99% iso alcohol and clean the connections and clean it up with a tissue. once dry i would heat the processor up slightly with a heat gun for a few seconds
完成的
And will it work after that?
完成的
probably not, but there is a chance that it would so it is worth it. The logic board pretty much IS the phone. They have the same value.
完成的
But why the heat gun i don't have one. Could i use a hair dryer?
完成的
显示更多的2条评论
添加一条评论
The common problem in mobile phones is over heat&battery drying problem.
some of the suggestions are
i)check ur battery
ii)check battery case
iii)do not run more apps at the same time .
iv)restart ur phone by pressing sleep& power button untill the image appears.
这个答案有帮助吗?
得分 0
1条评论:
Once again the phone dont boot up and the battery is fine
完成的
添加一条评论
添加你的答案
akash 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 343
