跳转到主内容
The Sony Xperia M2 is mid-range 4G Android smartphone produced by Sony Mobile. Available - May, 2014.
34 个问题 查看全部
Black Screen, Completely Dead already! PLEASE HELP!
This has happened to me three times now. Screen goes black and will not load up again for ages. Pressed the reset button far too many times already.(volume up n power off button) but still not workin
回答此问题 我也有这个问题
这是一个好问题吗?
得分 56
8条评论
plzz someone help !!!
完成的
i have to wait a minute and it comes good
完成的
Omg the reset feature helped me thank you osooooo much
完成的
Worked for me too. Thank you!
完成的
hi reset has not worked for me, please help
完成的
显示更多的3条评论
添加一条评论
3个答案
最有帮助的答案
https://www.youtube.com/watch?v=DU2u0ISz...
This should help your issue.
Please accept this answer or score if it has helped
这个答案有帮助吗?
得分 5
8条评论:
thanks it was solved
完成的
I tried. It doesn't work
完成的
@moiragabrielleh01 - what is the damage? did you drop the phone?
完成的
Just did this, like in the video it takes a few attempts but worked!
完成的
That is brilliant news @Cevaughan!
完成的
显示更多的3条评论
添加一条评论
Hold both power and volume up for 10 seconds. My phone just got blankscreen over an hour today, just did it and successfully worked! Hope this helps
这个答案有帮助吗?
得分 1
1条评论:
It wasn't work.... I need help for the sony xperia e3 all of the videos on youtube wasn't work
完成的
添加一条评论
i had such a problem too, my phone was flashed by some technician, but problem persisted. so i opted to change d battery and its perfectly working a gain....
这个答案有帮助吗?
得分 0
1条评论:
cange your baterai, i have that experience too
完成的
添加一条评论
添加你的答案
priyanka 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 93,380
