Is there a way to replace the camera on the display?
Whenever I open Photo Booth or Skype, my MacBook says no camera can be found. Is there a way to replace the camera or check if a cable came loose on the motherboard?
I've never seen the actual camera go bad. Most likely is a bad cable connection. Check step 6 of this tear down to make sure it's plugged in correctly. This is an easy fix. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Assembly Replacement
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 514
