跳转到主内容
加入维修社区 - 创建账户
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
Touch Screen stopped working
My touch screen just stopped working, did not drop it, has been inside a otterbox case. I did a soft and hard reset and still not working, so I replaced the screen and still problem. Does anybody have an idea of what went wrong?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
4 things need checking when touch-screen stops working:
1/ Software issues: you ruled it out since you did a hard-reboot. As an extra measure, you can restore from DFU mode: back-up your data since it will be wiped. Then press and hold Home Button + Power Button for 12 seconds, then release the Power Button but keep pressing the Home Button for 15 seconds. Then connect to the latest version of iTunes on your computer. It should tell you that it detected a device in Restore Mode (if not, goole how it's done and repeat). Accept the prompt to download and restore your iPad, and leave it connected until it's done. I doubt it will help but since it costs nothing, you can try it.
2/ The touch-screen connectors need re-seating on the logic board. Since you already put in a new touch-screen, your ruled out this possibility. You also in principle ruled out possibility #3:
3/ The touch-screen has gone bad and need replacing; note that the replacement touch-screen that you used could've been defective and/or damaged during installation (too much pulling on the flex cable). To be on the safe side, you can try using another known good touch-screen (no need to seal it in to test). And don't forget that the battery connector must be disconnected first before the LCD and touch-screen connectors!
4/ The circuit responsible for the touch function on the logic-board broke down. You will need micro-soledring skills, the right tools, and experience in trouble-shooting and repairing this kind of circuits.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mike 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 600
