跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
439 个问题 查看全部
I hear a popping sound and it shuts off.
When I turn on the 3DS it starts to power on and then I hear a popping sound and it shuts off. I tried removing the batter and putting it back in after a few minutes with no luck. I have taken the 3ds apart but all ribbons seemed to be seated well and there doesn't seem to be any tears in the ribbons. The only thing I noticed was the WiFi antenna is torn a bit. In all fairness I don't remember if I tried it with the WiFi off. Could the WiFi antenna cause this issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
2个答案
已选择的解决方案
If it pops and then turns off then you most likely have a torn ribbon cable. Sometimes they are very hard to see. The tears can be anywhere on the cable. Many times they tear at the hinge but they could also be torn elsewhere.
这个答案有帮助吗?
得分 3
添加一条评论
what do I replace in the ds to fix this solution?
这个答案有帮助吗?
得分 0
1条评论:
You have to find the ribbon cable that is bad and replace it. This is a very difficult repair so be sure you are ready and have the skills before trying to do it. The most common ribbon cable to tear is the speaker ribbon cable, but it can be the top screen cable too.
I hope this helps!
完成的
添加一条评论
添加你的答案
DJ Hotnisky 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 44
总计 3,399
