door does not open to put game in.
I can not get the original xbox door to open otherwise works fine.
Hey mate, this is a common problem with the original Xbox, due to their old age. Its due to a rubber belt in the disk dive stretching or braking. You can either fix the disk driver, by obtaining a new belt, or replacing the disk drive.
This tear down will show you how to open up your Xbox;
and these links will tell you in detail how to fix the disc driver, if you wish to;
http://www.ebay.com/gds/Xbox-Repair-How-...
http://www.gamefaqs.com/xbox/915780-xbox...
hope this helps you mate.
这个答案有帮助吗?
I've had the same problem before and it was indeed the disc drive belt.- I've actually found that is typically the problem
I had this same issue and i fixed it.
But it is a rubber belt that needs to be cleaned.
Use a paperclip to Manually reject. You will see a small pulley and a bigger one in the middle gap of the cd tray.
Use tweeters to take the belt out.
Use a damp paper towel to clean any dust/dirt from the small rubber belt.
Then carefully put the rubber belt back on.
Turn the system on...
This has fixed 2 system for me.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 15
总计 1,528
2条评论
How do i Fix It ?
由 rubencortezone 完成的
Hey mate, the method of fixing it, is bellow in answers section.
由 james 完成的
