跳转到主内容
Why won't my Mac sleep/wake when I close/open it?
I got my Macbook as a Christmas present this year, used. I noticed that when I close it, it takes about a minute for it to sleep (only because I set it to sleep after a minute of inactivity). Then, when I open it, it doesn't wake until I press something. I've tried doing many things, including "pmset -g assertions" and the only thing preventing it is "com.apple.iohideventsystem.queue.tickle" but it doesn't say anything like "preventsystemsleep". Is the sensor broken? How would I fix that?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
Did it always act this way? What OS are you running, The last two releases have had a lot of sleep/wake issues.
If you have not changed the OS you could have a corrupt .plist file.
Create a new user account and use it just as a test. Does it act the same or as you expected. If the behavior stops you have eliminated a hardware problem. You can go back to your main account and try to track it down (deleting a corrupt .plist file is a "fix" for strange application behavior).
If this answer is acceptable please remember to return and mark it accepted.
这个答案有帮助吗?
得分 2
2条评论:
It stayed the same way
完成的
Try the clean install as below, ''If you've opened the box you may not have the ''sleep magnets'' aligned.''
完成的
添加一条评论
I had the same problem. After spending 2h with the apple care hotline I had to do a clean install. But then it worked. Just make a time machine backup before hand in order not to lose date.
这个答案有帮助吗?
得分 2
添加一条评论
Most likely cause is an idiot who replaced the screen and messed up the sleep magnet. Second most likely cause is a liquid damaged BIL.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ellie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 964
